![]() | Home > Technical > 06 Range Rover starting issue |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5106 ![]() ![]() ![]() |
Maybe a power drain do u think causing battery To go flat when parked?
Cornishmike Member Since: 27 Aug 2023 Location: Cornwall Posts: 3 ![]() ![]() ![]() |
Hi Andy I have tried to start it with booster pack on as well but still the same |
New tcm may need programming,
Press in the ones that say fault and see what codes you get. |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 955 ![]() ![]() ![]() |
Is this a case of not starting or not cranking at all??,,, what exactly is the battery voltage when this happens?? . Simple things first,, battery terminals secure and tight,, earths on bodywork,, try putting a temporary earth from the battery to the engine block to see if it makes a difference,, if so check the main earth on the chassis. Change brake pedal switch another heap option. 2010 RRS, TDV8
