Home > General (L494) > Help needed! Want to retrofit a fridge in centre console
Bigmark66!
I have a RRS 2018 and want to retrofit a fridge in the centre console. I have the fridge from an auto biography does any body have any suggestions where I can wire this into. Was thinking the cigarette power supply but this is permanent live and I need a switch live so that it only comes on with the ignition .
Anybody ever done this?
Post #634834 Sat Aug 05 2023 1:12pm
TheWojtek
I don't think the cigarette lighter is permanent live. It's live on vehicle unlock, I believe. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #634836 Sat Aug 05 2023 1:59pm
Bigmark66!
didn’t think of that, Many thanks for your help.
Post #634838 Sat Aug 05 2023 2:33pm
NoExpert
I’ve never looked, but are the L494’s prewired for a fridge like the L320’s? Take a look before getting too crazy since it could already be in there.
Looking at parts listing there’s no fridge specific harness I can see so it’s quite possible it’s prewired and just needs to be plugged in. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #634846 Sat Aug 05 2023 6:12pm
Not sure on a L494 but on the L320 cigarette lighter becomes live when vehicle unlocked and stays live with ignition on, then when ignition switched off goes dead after a few minutes when vehicle goes to sleep if I remember right.
Post #634853 Sun Aug 06 2023 3:55am
Bigmark66!
Thanks all.
I’ve had a look and the wiring and connection is in fact there but has no power to it. Researched where the fuse is for it and put one in and still nothing. Any ideas?
Post #634868 Sun Aug 06 2023 1:35pm
NoExpert
Not sure if it’s the same, but my L320 fridge doesn’t go on till the alternator is pushing 13v. Did you test it with the engine running? I believe it is designed so that the fridge will not work without the engine running, as in turning on at 13v and shutting off with the engine. Have you tried just plugging in the fridge, starting the car and then turning the fridge on? Mine can have a delay till the alternator is pushing the desired voltage. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #634875 Sun Aug 06 2023 5:01pm
There must be a variation in some of the L320's as mine works as soon as you turn the ignition on or at least I can hear the fan running and the off as soon as ignition off, you don't have to run the engine. I imagine it would switch off if the battery got low without the engine running though, although I always leave mine switched off at the switch under the cubby box lid.
Post #634878 Sun Aug 06 2023 11:06pm
scrumps
Hi,
My 2019 AB came without the fridge I’d ordered (and dual sunvisors) so the Dealer fitted both before I collected the car.
As far as I know it was a simple job to fit it in place of the storage compartment.
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #634913 Tue Aug 08 2023 4:29pm
NoExpert
Could be, my fridge is out of a 2006 NAS RRS. I thought it was broke initially since when I hooked it to a battery it didn’t turn on. I then tried it with the car running and it fired up. I have a voltmeter in the car and 13v is the magic number it turns on at. It’ll stay on, even if voltage drops below 13v, and then shut off with the engine when the car terminates the power to it. Personally I like this setup. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #634915 Tue Aug 08 2023 5:18pm
