Home > Technical > 2nd battery ?
skullbiker
United Kingdom 2005 Range Rover Sport Supercharged Siberian Silver
2nd battery ?
Hi ,
I am new to Range rover sports .
I keep reading people refering to their second battery - what is that all about ? is this an addition people make or is a second battery standard to some models ? I am the darkness before the storm
Post #634274 Sat Jul 15 2023 6:59pm
It's the stop-start battery.
The earliest RRS models did have scope to add a second battery (an auxiliary battery that could be used for camping, winching, powering a caravan/trailer when the engine wasn't running) but that facility got eroded by the adding of hardware in the space. 2012 SDV6 - it's missing a couple of cylinders
Post #634275 Sat Jul 15 2023 7:27pm
skullbiker
Thanks
Thanks for explaining that . much appreciated. I am the darkness before the storm
Post #634276 Sat Jul 15 2023 7:44pm
Brian Considine
Something I was going to ask myself - I have a 55plate 2.7 V6 Diesel - will that have somewhere for a second battery & if so where please ?
TIA. 2006 RRS 2.7 HSE.
Post #634285 Sat Jul 15 2023 10:16pm
Yes, the L319 has a spot in front of the brake master cylinder under the big plastic cover that mimics the main battery cover. There is even a set of threaded inserts in the base of the location t allow for the holding down clamp. Also, if you look at the scuttle panel along the rear edge of the engine bay, you'll see it suits the running of a cable from the secondary location to the fusebox - there are even some useful holes for tie-wraps to secure the cable.
On models without the FBH (hot climates or the V8 petrol), the second battery can go where the FBH normally sits.
This one has yellow top batteries added to both locations:
Post #634288 Sat Jul 15 2023 11:03pm
Can't go there on the N/S of a 5.0 V8 petrol Sport if anybody was contemplating fitting one, as because there is a bleeding great air filter there. Thumbs Up
Post #634290 Sun Jul 16 2023 1:15am
The question was about 2.7V6 Disco, Col. So it's ok for that. Thumbs Up
On the 5.0SC, the location by the brake system is still available, isn't it? 2012 SDV6 - it's missing a couple of cylinders
Post #634295 Sun Jul 16 2023 9:13am
Don't think it would be worth the trouble Wayne, would need to move a ecu and some other wiring and electrics to fit anything bigger than a double AA battery in there. Rolling with laughter
Post #634297 Sun Jul 16 2023 9:33am
Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #634333 Mon Jul 17 2023 9:01am
