Home > Maintenance & Modifications > 4.2SC 2005 lower wishbones
JonnyCJ
What's the best place to get these from ? Lots of suppliers and I see they're just pressed steel rather than a cast item, so looking to the wisdom of the forum on what's the best route to change them.
Are they tricky to get out and do I need to replace the bolts as well ?
Jonny
Post #632637 Mon Apr 24 2023 8:57am
They aren't cast items, they're made from formed and welded sheet.
Advanced factors do an entire kit including the bolts with arms that have heavy duty bushes and the later, upgraded, ball joint.
https://www.advancedfactors.co.uk/kit683hd...6314-p.asp
Unless you're lucky, the arms usually need to be cut off as the bolts seize. So you'll almost certainly need new bolts anyway. 2012 SDV6 - it's missing a couple of cylinders
Post #632639 Mon Apr 24 2023 9:33am
JonnyCJ
Really handy kit that - save scrabbling around looking for the offset washers etc. Many thanks for the link and good to support the forum sponsors.
Order on the way !
Post #632644 Mon Apr 24 2023 11:05am
