Home > General (L494) > 2014 5.0 SC Autobiography - What to look for?
cedwat
France
Hi,
I am thinking about trading my 2011 fat Range Rover 5.0 SC Autobiography for a superb red November 2014 RRS 5.0 SC Autobiography.
I am going for a test drive in a hew hours.
The car seems in superb condition, it has 107.000 km on the clock, all Range Rover serviced except the last one.
I have been able to hear the idle it is okay (a little bit of tic tic tic, more than on mine which has 145.000 km, but seems okay).
What should I check other than that idle sound ?
Thanks.
Cédric.
Post #632416 Mon Apr 17 2023 2:42pm
besides the usual:
- Run the VIN through Topix to check for build & service history
- Make sure you don't hear any "Ticking" or "Clanking" upon start-up within the first 5 seconds... roll down all the windows before start-up
- Check air suspension by dropping/raising
- Run it over speed bumps and listen for any clunking (lower control arms)/clicking (CV joint) noises
And if you do buy it, replace the water pump & crossover coolant pipes (with aftermarket aluminium ones). Also get the ZF gearbox fluid changed every 80,000-100,000km. --
Post #632424 Mon Apr 17 2023 5:30pm
