Home > General (L494) > anyone else had 'P25A2-00' ABS / check engine fault code ?
John w
Hi all.
Bit of an odd one this, so wondering if others have encountered it, or know the fix.
Sorry for the long post, just explaining everything in one hit Smile
Background:
One of the deployable side steps on our 2015 autobiography is stuck, so i plugged in my obd tool.
Prior to this i had no dash warning lights.
during the scan (ignition on, engine off) the car turned itself off, so i stopped the scan unplugged and replugged the tool so it too started from scratch.
plugged the tool back in and turned ignition on.
I had all sorts of lights on and errors coming up, gearbox fault, no hill descent, etc.
I did a 'quick erase' on the tool to clear all fault codes, but am left with a couple i expected but one I don't (one step related, one to do with the 2nd battery for stop/start)
The real problem:
I have the check engine light on, and the fault code given is 'P25A2-00', Permanent, 'ABS control module requested malfunction indicator lamp illumination'.
This was not on previously.
When i perform a device scan there is no ABS module in the list. It does initially try to scan it but then moves on to the BCM.
So I don't believe there is a real fault here, but can't clear this code and not sure why I can't see the ABS module.
I did a web search and found some information for this exact fault on the USA nhtsa web site:
https://static.nhtsa.gov/odi/tsbs/2014/SB-10103181-9340.pdf
Our car is after the chassis number quoted.
From its description it sounds like a module might have turned an output on or off, and the way around it is to wire a permanent feed.
Has anyone else experienced this ?
Are there any techs on here that can confirm if this is likely the problem ?
Is there a uk equivalent tsb or recall for this ?
looking forward to your replies.
Many thanks,
John. 2010 L322 Range Rover Autobiography - Black Edition
2015 L494 Range Rover Sport Autobiography
Post #632051 Sat Apr 01 2023 10:28am
Dazel~259
Any luck, mines come up with P25A2 after a run out yesterday going into limp mode saying DPF full, cleared DPF down but P25A2 isn't & EML still on
Post #632253 Tue Apr 11 2023 2:42pm
John w
No, not addressed it yet. its not affecting the way the car runs or drives.
I did ask one main dealer and they said the car would need to go in and be inspected. Minimum of an hours labour. I assume so they can plug it in.
All I wanted was confirmation of whather the correct fix is the tech bulletin.
what I don't want is the dealer to start swapping modules at our expense.
If I get a resolution I will post it up. If you find one can you please do likewise Wink
Cheers,
Post #632272 Wed Apr 12 2023 10:57am
Disco_Mikey
Hard reset first. Disconnect battery for 5 mins, and retry Thumbs Up
Post #632274 Wed Apr 12 2023 11:45am
John w
Hi Mike,
good suggestion. I will give it a go at the weekend.
the car has a second battery too for stop-start, Do i need to disconnect that one too ?
Cheers, Thumbs Up
John 2010 L322 Range Rover Autobiography - Black Edition
Post #632286 Wed Apr 12 2023 9:18pm
Dazel~259
John i fixed mine by replacing the main battery as it was down to 394amps, new battery let it sit for an hour then cleared down all the faults & EML out & no stored faults Thumbs Up
Post #632448 Tue Apr 18 2023 7:50am
