Home > Technical > active anti roll bar
maci234
what is correct fluid for the active roll bars ,will any power steering fluid do
Post #631245 Tue Feb 28 2023 4:54pm
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi I use this been great https://www.ebay.co.uk/itm/Cold-Climate-Po...ct=mobile. Thumbs Up
Post #631247 Tue Feb 28 2023 5:54pm
The correct one is Texaco Cold Climate PAS Fluid.
Ravenol make a fluid that they say meets the requirements: https://www.ravenol-direct.uk/ravenol-ssf-...fluid.html
Others will doubtless do so too. 2012 SDV6 - it's missing a couple of cylinders
Post #631248 Tue Feb 28 2023 5:57pm
maci234
thanks alot
Post #631249 Tue Feb 28 2023 6:09pm
Iomegas
Hi just double checked on the one i recommended and it says
Cold Climate PSF is particularly suited for use in Landrover Active Cornering Enhancement (ACE) systems, as well as other power steering systems where improved cold performance or a fluid of this quality is required.as said though there are other brands. Thumbs Up
Post #631250 Tue Feb 28 2023 6:09pm
Disco_Mikey
We use Ravenol SSF Thumbs Up
Post #631258 Tue Feb 28 2023 9:40pm
maci234
Post #631263 Tue Feb 28 2023 10:38pm
