Home > Technical > rf reciver
karlos01
rf reciver
does anyone know the frequency for a 2006 RF reciver please
Post #630801 Sun Feb 12 2023 6:59pm
U.K. is 433Mhz I believe.
Post #630804 Sun Feb 12 2023 9:59pm
Disco_Mikey
Correct. 433MHz for UK Thumbs Up
Post #630805 Sun Feb 12 2023 10:23pm
karlos01
thanks for that it sounds silly but I think my neighbours ring door bell is interfering with the RF reciver on my sport
Post #630807 Mon Feb 13 2023 11:22am
nigels888
if you have problems and the issue is always at your house in the same place then you can ring ofcom and they will come out and pinpoint to the house who is causing the problem. it is free unless it is your house causing the problem then it is £90.
how do I know because I was blocking the whole street plus houses behind with something in my house
Post #630809 Mon Feb 13 2023 1:10pm
karlos01
thanks for thats nigels88 not had issue with it before till neighbour had doorbell fitted going to park over other side of drive and see if that makes difference first
on my old P38 I had to move my wireless router cause it was picking it up and keeping the becm awake
Post #630810 Mon Feb 13 2023 2:09pm
nigels888
and I also have the google/nest equivalent of a ring doorbell that mine is parked right outside of and it doesn't interfere
Post #630815 Mon Feb 13 2023 3:07pm
karlos01
I'll probably do like you suggest and contact ofcom and see what they come up with
Post #630821 Mon Feb 13 2023 7:33pm
