![]() | Home > Faults & Fixes > Range Rover sport l320 passenger heated seat not working |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5066 ![]() ![]() ![]() |
Read fault codes if you have a tool.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9078 ![]() ![]() ![]() |
It could be that the element has burnt out. The seat base and the seat back elements are in series so if one fails they both fail. In that age of vehicle, a burnt out element isn't out of the question.
Hemo Member Since: 17 Jan 2023 Location: London Posts: 4 ![]() ![]() |
Thanks! Will do that. Although the garage guy said that this won't show in the log. |
Thanks! Will need some skills to take the seats off and look at the elements. Do you think I can connect the two elements on the seating area on their own if the element of the back seat is the issue? |
No. Unlikely
If it is a burnt out element, they're not too bad to do. When I had one go, I got the bits and had my indie do the work replacing them. I got a base (mine was cracked for some reason), a new foam pad and the heating element. They just charged me a bit of labour. 2012 SDV6 - it's missing a couple of cylinders
Thanks both! Will see what is the issue. |
