![]() | Home > Technical > RRS Heater cool on passenger side. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5106 ![]() ![]() ![]() |
Well the auxiliary heater (as per fault code shot) goes along way to producing heat in these chilly conditions. (Well when it’s less than 5C outside )
AIJ 615 Member Since: 19 Sep 2022 Location: Tamworth Posts: 122 ![]() ![]() ![]() |
Ok thank you for advice. So would you think the initial cold air blowing on passenger side (even after 30-45 mins in car journey) is due to the ‘left temperature damper motor’
Also, anyone know what the FBH nunber is for when I look for it or what the diagram is. I’ll check under bonnet and try this step first |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5109 ![]() ![]() ![]() |
If you are referring to the FBH fuse number, check Fuse No. 2 under bonnet mentions FBH or possibly No. 28 as that mentions Diesel Aux heater, if it is the same as a 12/13 car.
