Home > Technical > Rear Demister stopped working, Underspoiler connector is ok
eddie flaherty
Hi Folks, having a nightmare with rear screen demister, stopped working around 2 weeks ago. Switch on centre dash consul lights and I can hear a click from a relay. Fuse is ok but there is no power to connector under rear spoiler. Cant find the clicking relay to try replacing it. Any idea where the relay might be?
Also Battery is good and still no power when engine running.
Post #629484 Wed Dec 28 2022 7:27pm
What year is your car?
You can’t replace the relay.
Make sure the engine is running when checking for voltage.
I can only suggest you drop the headlining at the back (start at center) and check for voltage before t enters the tail gate
Post #629485 Wed Dec 28 2022 7:44pm
eddie flaherty
It is a 2007. OK got a few days off work will try to trace if there is a break in cable. thanks
Post #629486 Wed Dec 28 2022 8:32pm
