![]() | Home > Technical > hdc fault |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5134 ![]() ![]() ![]() |
Is that code not showing a dodgy brake light switch, which is not uncommon and can cause the HDC to throw a wobbly I believe. Could do with the other two digits that go with that code as there are several that start P0504, although they all suggest a switch failure as one of several possible causes.
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
thanks col
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 148 ![]() ![]() |
I get this once every 10-18 months. Brake switch is the solution. |
hi folks got a rear wheel speed sensor subfault (ABS sensor) I've cleaned the connections and checked for splits in wires but when I removed the sensor from housing I've noticed it has a Grove cut in it
just a update on this
