![]() | Home > Maintenance & Modifications > Transfer Box Oil |
Have a look here for spec.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5132 ![]() ![]() ![]() |
If you Google IYK500010 which is the Transfer Box oil, it will throw up some options/alternatives like Ravenol TF-0870, Shell-TF0753, but as it is a "specialist" oil I think you options may be limited, the diff oils should be easy enough Fully Synthetic 75w-90, unless you have a locking rear diff which is a different spec.
DRW Member Since: 10 Nov 2022 Location: Brecon Posts: 33 ![]() ![]() |
OMG if you think your RR is performing badly just wait until Halfords have played with it ?? |
