![]() | Home > Maintenance & Modifications > Headlight Bulbs |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1210 ![]() ![]() ![]() |
some of the US owners have taken to switching to LED bulbs, e.g., https://www.amazon.com/dp/B0B1TXB9HG/ --
DaftRascal Member Since: 08 Nov 2022 Location: Ayrshire Posts: 28 ![]() ![]() ![]() |
I have a set of Osram ones here but they don't fit
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
I early RRS uses D2S
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9152 ![]() ![]() ![]() |
There are two bulbs - the HID one and an H7 "fill in" bulb that only comes on with main beam (it isn't "the main beam"). If you look on the top of the headlight, where the clear front plastic laps over the body of the headlight unit, you'll see which bulbs are fitted as it's embossed in the clear plastic. You might need to check both units as it can be faint. Example:
The H7 is indicated at the left of the picture (this is the nearside headlight on a 2008 TDV8), and the HID is at the right (you can just see "D1S" at the right hand end of the light unit). 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
They would be illegal for road use in the UK. They are available but for "show purposes only" or similar "please don't sue us" wording. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
