Home > Technical > Front diff rebuild. Set-up specifications (LR006011)
Kzwpoas1
Hello,
Can anyone point me in the right direction for the correct factory specs for a front LR006011 front diff rebuild?
I have a RRS HSE, 3.6 TDV8, 2009. Original diff part number: LR006011.
1. Pinion bearing preload (used)
2.Backlash
3.Ring gear bolt torque
4.Bearing cap torque
I will have my front diff rebuilt by a specialist but I want to double-check the exact specs with him as I am not in the UK.
I will use a quality Timken bearing kit ( DA5039)
Thanks and cheers.
Post #628002 Mon Nov 07 2022 2:03pm
You can download the workshop manual here: https://www.mediafire.com/file/yunzrqm47py...6.pdf/file
That might have the information you require. 2012 SDV6 - it's missing a couple of cylinders
Post #628003 Mon Nov 07 2022 2:24pm
rayodunne
Canada 2009 Range Rover Sport Supercharged Santorini Black
Hee a great thread with lots of info. The actual specs you are seeking are much like a unicorn.
https://www.disco3.co.uk/forum/topic134360-75.html 2009 Range Rover Sport Supercharged
Post #628014 Mon Nov 07 2022 8:30pm
