Home > Technical > 2012 SDV6 Coolant Leak
brimfull45
Hi,
I noticed yesterday that my coolant was sitting just below the minimum level so topped it up and then saw some dried coolant sitting below a pipe on the top of the passenger side of the engine.
Has anyone else had a leak from the same area and if so which pipe/pipes need replacing?
I have attached a photo for reference and you can see the pool of dried coolant sitting below the pipe where it connects.
<img>
Post #627803 Mon Oct 31 2022 12:37pm
brimfull45
2012 Sdv6 egr cooler leak
I believe the leak is from where the pipe connects to the egr cooler?? Anyone know if its a gasket or o ring. I have searched the net but not been able to find the answer.
Post #627810 Mon Oct 31 2022 10:42pm
dangermousehouse
Australia
Just wondering if you found out the answer?
I have a similar issue Less is more, more or less
Post #635151 Sat Aug 19 2023 4:01am
NoExpert
That pipe is part of the EGR assembly. They don’t list a separate seal for it. Sadly may be a new EGR.
Be sure it’s not the hose leading into it that’s leaking. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #635165 Sat Aug 19 2023 12:46pm
Mike London
I have the same issue. Booked in for new EGR Cooler since pipe and O ring not sold separately! 2014 RRS AB Santorini Black
Post #636605 Sun Oct 15 2023 1:59pm
