Home > Technical > EPB repair path
alfapat
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
EPB repair path
So looked at various and many threads on EPB faults.
The code is U2002-01(BCool The mechanism has been working fine , but since being in off road mode and starting the car the next morning and dropping it to normal , the red P blinks along with amber brake warning . I never used the parking brake overnight.. Where can I start please, the epb switch does not operate now, I have 11.45 plus v on green yellow (I will confirm this) on switch plug and lower volts on another, will confirm this also.
Do I remove the spare wheel to get at the multi plug I see from below and test at that end , I don't know where the cable is from the tunnel underneath. Does this go to a multitude of wires lying on the rear left chassis perhaps just to left of the spare wheel?
I just need some pointers please.
Post #627180 Wed Oct 05 2022 7:22pm
11.45V seems rather low. I'd start by charging the battery. 2012 SDV6 - it's missing a couple of cylinders
Post #627181 Wed Oct 05 2022 7:29pm
alfapat
The battery is good . Its showing over 12.30 and 14v engine running.
Could be a bit of resistance from junction to switch though.
I will test while engine running.
Post #627184 Wed Oct 05 2022 8:04pm
jimbg
That's low, a fully charged battery should 12.7 or above. 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #627187 Wed Oct 05 2022 9:29pm
alfapat
Ok I'll check this , but I haverun the car back and forth with it showing 14v and above and its not doing much difference for brake function.
Post #627189 Wed Oct 05 2022 11:10pm
alfapat
Testing wires with engine running and showing 14v at the dash with GAP IId connected. The wires on the park sw. plug connected are Y 6.33v, YB 10.95v , YG 6.47v, and Red 5.5mv. Earth black 0.0 ohms.
So from that I expect a high resistance if those voltages are incorrect.
If I drop the spare wheel to get access and buzz out the connector on the rear nearside chassis back to PB switch is that where the PB wiring meets up before the connections to the module?
Post #627209 Thu Oct 06 2022 8:37pm
alfapat
Sorry missed out another Red wire showing 8.16v
Post #627210 Thu Oct 06 2022 8:44pm
alfapat
Sorry missed out another Red wire showing 8.16v .
Tried to edit in last post .
Post #627211 Thu Oct 06 2022 8:46pm
Well a quick search on disco3 for that fault code U2002-01 suggests you need a new dash park brake switch !
Got to be easier than getting under the car
Post #627222 Fri Oct 07 2022 4:37pm
£40 on eBay
I’m not sure if the contacts inside are like a tv remote control and can be cleaned with ipa or aftershave
Post #627223 Fri Oct 07 2022 4:41pm
alfapat
I reckon the previous voltages are from a can bus so will be lower.
I will buzz out the lines to and from the switch and module.
Watch this space.
Post #627225 Fri Oct 07 2022 6:25pm
£40.00 on fleabay £30.00 from a dealer. Smile sounds about right.
Post #627226 Fri Oct 07 2022 8:45pm
alfapat
Aha , seems that the red wire I found earlier was on MV.,(see earlier thread) was the culprit , it was the only one showing open circuit. Spotted a white spot further off the plug about 5 inches from the plug and yes corrosion, soldered and reconnected, hand brake working ......Get On ! Ordered some heat shrink to protect the joint and bingo , fingers crossed.
Post #627227 Fri Oct 07 2022 9:05pm
