![]() | Home > Technical > What’s the trigger / bottom on the gear leaver |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5134 ![]() ![]() ![]() |
Are you referring to the release button to shift the gearstick out of park/reverse etc.? only you shouldn't be able to move the stick from park unless you press it in, all works in conjunction with the transmission interlock solenoid I believe.
AIJ 615 Member Since: 19 Sep 2022 Location: Tamworth Posts: 122 ![]() ![]() ![]() |
Thanks Colin
Perfect, appreciate this - thank you
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5124 ![]() ![]() ![]() |
It doesn't need to be pressed when moving between D and N |
