Home > Faults & Fixes > Adaptive Damping Issue
h5muu
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Alaska White
Afternoon, wondered if anyone has knowledge on a couple codes that popped up today.
ADAPTIVE DAMPING CONTROL MODULE - CODES 2
-C110D-64 FRONT RIGHT DAMPER SOLENOID
-C110D-14 FRONT RIGHT DAMPER SOLENOID
Thanks , any help would be great as the ride has gone to jelly, no fluid leak and the air suspension works fine.
Thanks H
Post #626602 Mon Sep 12 2022 2:18pm
I think I would start by checking the electrical connector and wiring coming out of the top of the damper, to make sure the wiring isn't damaged and the connector has a good connection. You can actually buy a new wiring kit (LR018192) for the damper part, whether that is a indication the wiring can be troublesome or not wouldn't really know, I think the solenoid it's self may be a integral part of the damper and not serviceable on it's own, but could be wrong on that one.
Post #626607 Mon Sep 12 2022 9:34pm
