![]() | Home > Technical > Brake Failure, oil in servo RRS 2.7 tdv6 2007 |
Stand Easy Member Since: 10 Aug 2016 Location: Manchester Posts: 126 ![]() ![]() ![]() |
Hi pal I had the exact same scenario, recall carried out on my 2005 2.7 prior to my ownership then had the same hard pedal symptom. JLR were not interested in fixing it again. I paid a good independent to sort it but you likely need the following items replacing.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4505 ![]() ![]() ![]() |
As above. Reqs new vacuum pump and servo, and if the brake fluid has been contaminated, a new brake master cylinder too |
