![]() | Home > General (L494) > Boot Right Hand Fuse box - Is mine different |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 318 ![]() |
So I’m just checking my fuses as I think the sub issue could just be simply a fuse.
Struggling! :/ |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5151 ![]() ![]() ![]() |
Not sure which year these illustrations apply to, but are you sure there is not a second lower fuse box in the bottom lower r/h corner?
Thanks @colb:)
The top right of the lower illustration is the boot space, ringed item is the lower fuse box.
Ah great thanks will double check this morning 👍🏻 |
So I found the lower fuse board! It’s the next panel along where tow bar buttons are installed.
