Home > Maintenance & Modifications > Fault. Electrical or other....??? |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 407 |
Here's hoping one or more of you knowledgeable people out there can help.
Fri Jul 08 2022 8:20am |
Mechanic has said that the exhaust problem is actually a split pipe running from the engine to the exhaust system...(my son's words), and is an easy fix, but not related to the car failing to start when hot.
Thu Jul 14 2022 3:08pm |
New ECU installed as above, but car still seriously squeaking and noisy around front suspension when hot, especially when turning slowly and going over speed bumps.
Mon Jul 18 2022 7:48pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1244 |
Absolutely no idea. Squeak has to be bushes surely. 2006 2.7 TDV6 HSE in Cairns Blue. |
Mon Jul 18 2022 9:08pm |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 304 |
Arb bushes |
Mon Jul 18 2022 10:40pm |
Thanks guys, that's what we're thinking. Barrie.
Tue Jul 19 2022 6:42am |
What he said. Always happens with mine when it hot and dry weather. And you've had a bit of that in Portugal recently. There are various posts on this forum about changing them or updating to different materials. But first thing to try is liberally squirt them with WD40 and see if the squeaking stops (if only temporarily). Then at least you know what it is Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Wed Jul 20 2022 5:20pm |
OK, thanks. Can I just query though... WD40? I've seen on some threads that it's better to use a silicone spray for lubrication. Just to be sure...? Barrie.
Wed Jul 20 2022 6:23pm |
My indie used WD40 but I guess a silicone spray would be a better bet as long as it will crawl into those minute gaps between the bush and the bar Robin
Thu Jul 21 2022 8:57am |
The new ECU has solved the starting issues. Sorted.
Tue Aug 16 2022 3:44pm |
Ouch!. If its any help, I just checked back and in Jan 2017 I had a front wheel bearing changed - cost £212. Never had the ACE changed so wouldn't know the price of that Robin
Tue Aug 16 2022 3:56pm |
Thanks @Eaters. The wheel bearing is about 230. No problems with the costings, just a bit gutted for him. It's a beautiful car and he wants to keep it. Once this is done he'd have paid out about as much on his 2012 in a few months as I have my 2005 in over 5 years. Barrie.
Tue Aug 16 2022 4:06pm |
If its any comfort, when I bought mine it went through many many fixes and replacements in the first few years. The last couple of years have been relatively quiet. I know there will be things coming up around the corner but am just glad for each day that passes without having to dip into my ever depleting wallet. I won't bore you with the full details of the spreadsheet I keep but my total outlay on spares, faults, repairs, tyres and servicing is currently £13,402. my warranty covered it for three years and so reduced this outlay by £2,318 so a net cost of £11,084. That's over 77 months ownership. I still have to call it my hobby as my head says buy a Vauxhall Astra - REALLY??? Robin
Tue Aug 16 2022 4:19pm |
Barrie.
Tue Aug 16 2022 5:17pm |
