Home > Maintenance & Modifications > REPLACE TDV6 with SDV6
robwehittock
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
Hello
I have a 2011 RRS HSE with a TDV6 3.0 (broken engine) and want to replace it with a SDV6 3.0 engine from a 2018 RRS HSE.
Can I simply insert the SDV6 engine into the 2011 RRS? The advantage of just inserting the SDV6 engine is it has the more powerful turbos.
If not what do I need to change?
One alternative I have thought of is to just use the block from the SDV6 and use the turbos and wiring hardness from the TDV6.
Any advice greatly appreciated.
Post #625052 Mon Jun 27 2022 6:53pm
Disco_Mikey
Not that simple
Gen 2 engine has variable flow oil pump and water pump, as well as completely different EGR system and DEF functionality
They are not compatible without major reworking
Post #625053 Mon Jun 27 2022 7:07pm
robwehittock
The SDV6 has been stripped right down to the block. How would you suggest rebuilding it so it can be put into the 2011 car?
Post #625054 Mon Jun 27 2022 7:19pm
