![]() | Home > General > Engine system fault |
Shaun W Member Since: 03 Mar 2020 Location: Dewsbury Posts: 80 ![]() ![]() ![]() |
Any smoke from the Exhaust?
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 953 ![]() ![]() ![]() |
Easiest and cheapest starting point would be to blank off the egr valves seeing as you have the 2.7,, only thing on yours is I think you may need a software update to keep the engine management light off,,,, then see how it goes. 2010 RRS, TDV8
Sean1884 Member Since: 01 Aug 2021 Location: Derby Posts: 6 ![]() ![]() ![]() |
Thanks for the responses. Not aware of any smoke.
harry_57 Member Since: 06 Aug 2011 Location: Ruislip Posts: 7 ![]() ![]() ![]() |
Sean ... did you ever get it solved ? |
