![]() | Home > Maintenance & Modifications > Corroded hydraulic lines. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4527 ![]() ![]() ![]() |
Not full body off, but the back and front both have to be separated to replace the respective pipes |
Gas-guzzler Member Since: 28 Dec 2021 Location: Paisley Posts: 64 ![]() ![]() ![]() |
Gosh, that was a quick reply. Thanks. It’s going in for air suspension fault finding soon so I’ll get a quote then. But not good hey! |
Even worse that the pipes are on back order too...
Oh god, are they back order.. looks like I’ll be keeping my fingers crossed for the time being.. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5134 ![]() ![]() ![]() |
Never looked into it but often wondered if some one like Pirtek could make up flexible pipes to replace them with or at least part off, I guess the problem might be finding a fitting to actually fit them into the valve block though.
When the pipes are in that condition though, it's difficult to join into...
Yes, I was wondering the same about someone like Pirtek making a flexible version of the lines possibly then avoiding the body split. I don’t know enough about it but possibly cutting out the old rigid lines in pieces then routing flexi ones to replace. Or is it gaining access to connecting the lines to the pump and the roll bars? I’ll look into that too. Thanks guys.. |
