![]() | Home > Maintenance & Modifications > Spark Plugs for L494 SCV8 |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1200 ![]() ![]() ![]() |
Hi,
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5114 ![]() ![]() ![]() |
Manual say's 1.0 mm (0.03937 in) I do have a new set here somewhere of LR032080 which are the ILKAR7C10 will check what they are gapped at from the factory if I can find them.
thanks Col |
Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 289 ![]() ![]() |
Looks like 1mm gap to me. Sorry for using an uncalibrated 30cm ruler.
All good, Col, thanks a lot.
Just checked the set I have here, all gapped at 0.038" from the factory. Also remember seeing this so maybe genuine factory supplied one's are pre-set from factory. S/C belt recommended change at 7 years as well if I remember right, although did Aux belt as well when did mine as you're half way there.
