![]() | Home > Maintenance & Modifications > Fuel Pre Heater problem |
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 ![]() ![]() |
Hi,
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 346 ![]() ![]() ![]() |
Many thanks riverblanche for feed back. Could you explain your suggestion " have a look over on D3" Not sure what that refers to? Understand your point about better to have the Fuel Pre-Heater working. I don't feel confident enough to strip the unit down myself but hopefully after looking at the section you are suggesting I look at, that might change! Andrew Kennedy |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
Thanks Andy K. I've looked at the information on the link you gave me........trying to sort out what might be the problem is above my capability. I'm coming over to the UK in May and will purchase a new Pre-Heater. Andrew Kennedy |
1. Where is the fuel spillage ?
Andy - No not all electrical connections have been separated. Looking in from the top, only the one on the top left has been taken out? Tomorrow I will look at the pipe and exactly where the leak seems to be coming from. Andrew Kennedy |
The big connector should be removed if it’s faulty. From memory |
Hi
Hi riverblanche. Thanks for the input!! You are quite right, it's the Fuel Burning Heater that's causing the problem! The problem being in the cold weather it can omit a tremendous amount of smoke and leaves a deposit of unburned fuel on the 'ground emanating form its exhaust pipe. I purchased a used one from a later model from a breaker in the UK. Total cost was £84.00 with postage plus import duty - it didn't work so the original one was put back (there isn't a fuel leak, I think it was just a residue of fuel in the system when the old one was put back). At present the the electrical connection is disconnected. I have had the car (2006 Sport) since new. It hasn't done 100,000 miles yet and I'm keen to keep it in good order - if I have to buy a new Burner I will but is you have any suggestions as to what I can do to free up or clean it out........do please let me know. Andrew Kennedy |
If the replacement was from a later model, maybe you need to swap the PCB over.
Unfortunately Andy the second hand one was binned after finding it didn't work. James Barrington is the The Land Rover garage over here. He is extremely knowable and he could see before they put the second hand one on that it looked as though it wasn't going to work - overheated at some time. I'm temped to connect the original one up in this cold weather but if its spitting out unburned fuel...possible dangerous? Andrew Kennedy |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961 ![]() ![]() ![]() |
I had the same issue with mine,, spitting out excess fuel from the exhaust. I unplugged all of the cables from it to disable it as the weather at the time was getting warmer. I managed to get a new set of seals then took it out and partially stripped it down,, didn't want to dismantle the electrode etc as some of the washers on the burner cup are not available to buy,,, and are very fragile. Settled for cleaning out the burner cup and Petit all back together and after a couple of false starts it's worked fine since. If that hadn't of worked I was going to buy a new burner module which is basically the heart of the unit,,,, I think it was Rimmer bros that have them at £150 or thereabouts. This gives you a new fuel cup, ignition electrode, sensor. Other thing to make sure is that the bowl is not choked with soot / carbon as this stops the unit from burning properly.
Hi,
Thanks for the info!!!! I think I'll take out fuse 28 and get my local LL guy have a look at the various post. Andrew Kennedy |
