Home > General (L494) > Front Knuckle Joint replacement after sub frame removal
Rowdie
Hi
Can I gather opinion please. Due to a leaking Hydraulic pipe at the front under the 494, My Stealer has has to remove the sub frame from the car to access the pipework for the Dynamic ARC system, replace the pipework then replace a front knuckle which broke during the removal of the sub frame, and then reattach the sub frame. This cost Extended Warrantee nearly £5k and the "Land Rover Warrantee" people were absolutely brilliant !. I am not a car expert, but surely after replacing the Knuckle and Sub frame, the car would need its tracking done wouldn't it ?.
When I asked the dealer they said they didn't know if they had done it or not... Should I worry or not ?. The tracking was only done a month before the car broke down as well
Thanks for any Advice
Post #622410 Thu Mar 03 2022 9:34pm
