Home > Technical > 2016Range Rover Sport ACE Line replacement
Skywagon Boy
Canada
Any input on ace kine replacement on our 2016 Range Rover super charge would be appreciated. The dealer is telling me it will be over 9000.00 as the body has to be remover. Is there any other way and does any one know of any recalls this seems ridiculous!! Thanks in advance
Post #621836 Sun Feb 13 2022 3:10pm
Disco_Mikey
Front or rear pipes?
Post #621838 Sun Feb 13 2022 5:32pm
Skywagon Boy
Canada
They told me they are the hydraulic lines that run from front to the rear of the vehicle.
They claim the body has to come off the frame. I wondered if there is any way of running them else where they claim not
Post #621848 Sun Feb 13 2022 10:44pm
Skywagon Boy
Canada
it is both front and rear lines part numbers LRO85490, LRO85489, and valve LRO72419
And the labour total cost of 9600.00 can this possibly be right?
Post #621850 Sun Feb 13 2022 10:58pm
I stand to be corrected here, but do they mean front and rear subframes ? as I though the L494 was mono frame style construction which means the actual body cannot be removed from the chassis/frame.
Post #621851 Sun Feb 13 2022 10:58pm
Disco_Mikey
Col is correct, body is a monocoque with front and rear subframes
Also, only 4 pipes from front to middle of the car, and 2 pipes from middle to rear, all meeting up at the valve block in the centre of the car
Post #621852 Sun Feb 13 2022 11:22pm
Skywagon Boy
Canada
How dies this pricing seem to you? Parts are two lines, and a new valve block
Post #621908 Tue Feb 15 2022 1:54am
Is the 9600 including parts or just labour, assuming that is Canadian dollars that's around £5500.00 UK pounds which if just for labour seems a awful lot of money to me, but Disco Mikey could probably answer that best.
Post #621910 Tue Feb 15 2022 3:35am
