Home > Technical > warning lights
karlos01
warning lights
wifey called me today saying all these lights came on today with parking brake fault and HDC fault would I be right in thinking something to do with battery plus she was told she has a brake light out
she is away for the night at work so can't get to look at it properly just would like to put her mind at ease
Post #621508 Wed Feb 02 2022 8:58pm
fairly normal for a RR Rolling with laughter
Fix the brake light soonest, as that can causes these problems.
I would be tempted to say the steering angle sensor may need calibration with the right most light being on too
Post #621510 Wed Feb 02 2022 9:24pm
Eaters
And I would use a quality replacement bulb for the brake light. Also consider replacing the brake light switch Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #621511 Wed Feb 02 2022 9:29pm
karlos01
thanks guys I've got some bulbs to replace the faulty ones will be first job when I'm back from work I did say would be something silly but you know women they panic
Well she does more about the RR than the other car 🤣🤣🤣
Post #621518 Thu Feb 03 2022 7:28am
karlos01
anyone help why I've got these messages on dash I've changed faulty bulb and get this on dash when push button for suspension hight it just beeps at me
Post #621536 Thu Feb 03 2022 6:53pm
Scrumpy
I had this on mine some time ago and if I remember correctly it was fixed by replacing the battery.
Obviously worth checking the voltage on rest and when charging to make sure before shelling out on one. 2016 RRS SVR Estoril Blue
Post #621539 Thu Feb 03 2022 8:48pm
karlos01
was thinking about putting the battery on charge and see if that would help
it won't let me raise or lower the suspension on it either
Post #621540 Thu Feb 03 2022 8:56pm
Eaters
I second this as a route to follow if for no other reason than it’s free to do, assuming you’ve got a multimeter. But if that shows no issues then perhaps a visit to a local tame indie (if available) for the faults to be read would be better than spending to long or too much on replacing bits that may be don’t need replacing Robin
Gone:
MGZTT 190 2.5
Post #621564 Fri Feb 04 2022 12:12pm
karlos01
just quick update charged the battery had diagnostic put on got all the lights off apart from adaptive front lighting system this stays aluminated then after a drive down the road all the other lights come back on
Post #621612 Sun Feb 06 2022 3:59pm
karlos01
think I've cured the problem it was the adaptive lights took head lights out both connectors was covered in crud clean with rag and some connection cleaner put back together and now all the lights are off and the headlamps are moving again
Post #621615 Sun Feb 06 2022 4:45pm
Eaters
Nice one! Don’t even get me started on what happens if your adaptive headlights give up the ghost😂 Robin
Gone:
MGZTT 190 2.5
Post #621628 Sun Feb 06 2022 9:46pm
karlos01
I was pleasantly surprised at how easy it was to remove the headlamps no nuts or screws just sliding lock pins
bet the headlamps don't come cheap lol
Post #621638 Mon Feb 07 2022 7:11am
karlos01
bloody thing spat it dummy out again had all the fault lights come back on did a live diagnostic test with my hawkey and it popped up with this
all the hdc fault and suspension lowered and park break fault all back on again with the adaptive lights warning again
Post #621666 Mon Feb 07 2022 7:41pm
karlos01
fixed it finally after been to body shop for some work
new ABS sensor fitted all faults gone
HDC suspension lowerd and special programs not available on dash even the adaptive head lamp fault has gone
Post #622775 Sun Mar 13 2022 6:49pm
