Home > Technical > Heater plugs !
Kevin-t
Heater plugs !
Hi guys.
Just a quick question if I may.
Having had a Discovery 3 for many years, I used to turn the key to warm up the heater plugs then start the engine after light goes out..
How does this procedure work in the sport? With the start button, as apposed to key start.
Would I be right in assuming you press the start button without foot on the brake. Then after a short while apply brake and start.
Thanks in advance.
Kevin Rangerover Sport 2016 4.4 sdv8 A/B loire blue.
Post #621466 Tue Feb 01 2022 2:59pm
gogsy1956
Not sure if yours would be the same as mine but,, foot on brake, press start for a couple of seconds,,, after a few seconds ( depending on how cold it is) engine will start,,, but you need to keep your foot on the brake all the while. Sometimes the " few seconds " seems like an hour. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #621467 Tue Feb 01 2022 5:30pm
Dave B
Press the button without your foot on the footbrake, you should have a glowplug light on the dash, once this goes out, foot on the brake and press button again.
Dave 2010 3.6 TDV8 HSE (Gone)
Post #621469 Tue Feb 01 2022 6:04pm
NoExpert
As said, foot on brake, press start button, wait and it’ll start when they’re warm. It’s hovering around 0° here so startups can take sometimes ten or so seconds. I have the timed heater enabled on mine, this helps cut the wait time down a lot since the engine and interior are already warming up. However, on the weekends I notice the longer delay to start since I rarely go anywhere at the times the FBH runs. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #621476 Tue Feb 01 2022 9:33pm
Post #621478 Tue Feb 01 2022 9:49pm
Grimble
I have never had to wait more than a couple of seconds before it fires up, even when the temp is showing a minus number. RRS HSE Dynamic SDV6 2014
Nemo mortalium omnibus horus sapit
Post #621489 Wed Feb 02 2022 11:06am
Kevin-t
Thanks Guys.. Thumbs Up Rangerover Sport 2016 4.4 sdv8 A/B loire blue.
Post #621494 Wed Feb 02 2022 3:46pm
