![]() | Home > Maintenance & Modifications > When should I be concerned about my turbos? |
Nilrem280 Member Since: 02 Jun 2020 Location: Portchester Posts: 84 ![]() ![]() ![]() |
My independent said other than regular oil changes there's nothing you can do to prevent turbo failure. |
peterjj Member Since: 15 Mar 2017 Location: Canberra Posts: 49 ![]() ![]() |
Might not be able to prevent the turbos wearing out but here is one check to stop a slowly leaking turbo oil seal from taking out the whole engine.
MartinsTDV8 Member Since: 22 Feb 2017 Location: County of Sutherland. Posts: 140 ![]() ![]() ![]() |
You can ‘look after’ your turbos though.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9139 ![]() ![]() ![]() |
The TDV8's turbo issues are down to the space in the engine bay being too small so the turbos are mounted lower than would otherwise be ideal. This requires additional plumbing to get oil back to the sump etc. in situations where extreme side angles are encountered - admittedly not that likely for most RRSs but LR designed it to be a working off road vehicle, not a driveway queen.
Josh95 Member Since: 08 Dec 2021 Location: Belfast Posts: 49 ![]() ![]() ![]() |
Thanks for this!
