Home > Technical > heated screen
karlos01
heated screen
does the heated screen on L320 RRS have to separate fuses for heated screen as only one side works
could be a bad earth connection if so would the earth connection be located under the window scuttle trim the same as the p38 I owned a p38 before the Sport so know my way round a range rover a bit
thanks
Post #620959 Sat Jan 15 2022 10:43am
Check fuses 15 & 18 in engine bay fuse box. 15 is R/H section 18 L/H section.
Post #620961 Sat Jan 15 2022 10:51am
connections are inside the car, behind the A pillar. (one torx bolt behind the Airbag screw cap)
Kinda ribbon connections.
Always good to check you have power there, but you just know you will need a new screen!
Post #620965 Sat Jan 15 2022 11:14am
karlos01
thanks col I thought there might be two fuses
Post #620966 Sat Jan 15 2022 11:28am
karlos01
thanks Andy got a mate who is a auto electrician will get him to check with me
Post #620967 Sat Jan 15 2022 11:29am
karlos01
Andy is the A pillar passenger side or the drivers side
Post #620972 Sat Jan 15 2022 2:25pm
kas982
United Kingdom 2005 Range Rover Sport Supercharged Bonatti Grey
both sides, mine doesnt work either..lol
Post #620973 Sat Jan 15 2022 3:31pm
The side that doesn;t work
Post #620977 Sat Jan 15 2022 5:08pm
karlos01
thanks for that I wasn't aware it had a wire on either side of the pillar I thought it was connected at the bottom
Post #620980 Sat Jan 15 2022 5:44pm
