![]() | Home > Maintenance & Modifications > EGR blanking with pipes fitted |
BigBerthaTheRRS Member Since: 15 Dec 2021 Location: Market Drayton Posts: 23 ![]() ![]() ![]() |
Hi all. New to the site. I am having EGR issues: trouble starting in cold because valves sticking open, slow to pull away from junctions when engine is cold, stalling in neutral after starting up.
Hi Andy thanks for rapid reply! Hopefully my sig will be at the end of this message.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
undo the pipe at the EGR.
https://www.ebay.co.uk/itm/111425688704?ha...Sw65FXrKhg
I had mine done some 4 years ago. Blanked at the intake side but leaving the pipes in place. Also the butterfly was removed the the arm was kept in. No problems or warning light and never noted at any of the MOTs. 2006 2.7 TDV6 HSE in Cairns Blue. |
Thanks both. This makes sense. However I imagine its more tricky to get a tight seal at the end of the pipe using a single plate than it is when removing the pipe completely with 2 plates. Runs the risk of pulling in unmetered air and having the same issues that a stuck open EGR valve causes? 2005 2.7 tdv6 RRS Vin 6A |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 784 ![]() ![]() ![]() |
I may be wrong, but I seem to recall seeing some blanking plates with seals set into the face. |
you could try exhaust sealer paste I guess if you are worried.
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 321 ![]() ![]() ![]() |
I know I’m in minority here but I removed all the pipes on mine and fitted a blanking kit, the end pieces that fit into the inlet manifold will be caked in gunge so they need removing and clean the Y piece up after you remove the butterfly mine was yuk black oily s##t. I’ve unplugged both EGR’s gone through two Mot’s with no issues.
Hi all,
Sham91 Member Since: 24 May 2018 Location: Bradford Posts: 178 ![]() ![]() ![]() |
I had the egr's blanked on my RRS 2010 & remapped but never had the butterfly valve removed :/, is that the valve in the throttle body? RRS TDV6 2010 |
Yes it is. Steve
Does it need to be removed? I’ve not had any issues with it being in RRS TDV6 2010 |
There is a minor hesitation when pulling away if it’s left in.
