Home > Maintenance & Modifications > Gearbox flushing around Peterborough
Crraigymmmmm
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Hi All, any recommendations around Peterborough area for a Gearbox flush? Mobile would be better.
Mines a 2012 8 speed, no problems but due gearbox service.
Post #618127 Fri Oct 15 2021 12:44pm
Boxers
Avenger 4x4 in Peterborough 01733 266690/ 301118 did mine for me , great independent specialist.
Post #618128 Fri Oct 15 2021 3:24pm
Crraigymmmmm
Thanks Just called them, price seems fair but they dont use genuine ZF oil.
Does anyone know if the 8 speed filter change required the sub frame cross member to be dropped, I read that the 8 speed pan isnt as deep as the 6 speed do it isnt as much an issue.
Im thinking to do the job myself but with OE fluid and filter, I have means of measuring the oil temp etc for the filling part of the job, also im aware of how to get almost all the old oil out and not just the half from a standard drain so the job doesnt phase me. as long as getting the pan out isnt an issue.
I think on the 6 speed the old filter can be replaced with a metal one with separate pan to avoid taking the cross member out but ideally want to know from anyone with 8 speed experience if this is the same story.
Post #618130 Fri Oct 15 2021 4:49pm
DrRob
8 speed has an in line thermostatic valve to oil cooler.
I’d get it Megaflushed by a pro
Bodsy does loads and I see mobile.
Www.updatesbybodsy.co.uk * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #618138 Sat Oct 16 2021 8:08am
Crraigymmmmm
Thanks, Yeah I can monitor the temp to make sure the valve opens otherwise the box in underfilled
can anyone corroborate the things I have read about Flushing causing potential problems in gearboxes later on? Planet Gears in Peterborough (ZF Agent) told me this too or is it chaf? They basically told me that flushing is a last resort when you have problems.
Post #618168 Mon Oct 18 2021 8:46am
Scrumpy
I read this blog and decided not to go with a mega flush but instead, a gearbox service.
https://glenrands.co.uk/2021/03/28/know-yo...-dont-need 2016 RRS SVR Estoril Blue
Post #618189 Tue Oct 19 2021 9:45am
