Home > General > 2010 TDV8 cranks but doesn't start |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
Yes! Thank you
Sat Oct 23 2021 9:37pm |
By the way, I take it that was with the engine running given 14.5V. Do the numbers stay broadly the same with the engine off and just the ignition on? 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Sat Oct 23 2021 9:39pm |
Nilrem280 Member Since: 02 Jun 2020 Location: Portchester Posts: 84 |
Ignition On - Engine Off.
Sat Oct 23 2021 9:46pm |
Thanks! Definitely something wrong with my PCM then, either external voltage drop or internal.
Sun Oct 24 2021 8:23am |
Belled out all of the feeds (0Ohms to the relay) and the grounds (0Ohms to ground). I will admit I haven't tried back-probing the connector yet to make sure +12v is actually present and there isn't a low voltage feed for some reason but while googling I found this:
Sun Oct 24 2021 6:13pm |
I don't think it's a software issue unfortunately - I think the DC regulation breaks down internally.. I did speak to the chaps at Turners this morning though and they reckon they can resolve it either via exchange or repair in 99% of cases, so I'll pull the PCM and post it off to them next week; this week I think I'd rather concentrate on worrying about my wedding on Thursday!
Mon Oct 25 2021 2:33pm |
£600 later for a recon ECU and .. no change at all.
Wed Nov 24 2021 12:41pm |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 214 |
Oh dear doesn't sound good , I have an excellent indi in Peterborough not that far from you really Avenger 4x4 give them a call & speak to Alan I'm sure he could help very knowledgeable. |
Wed Nov 24 2021 1:11pm |
Cheers - if it's getting repaired I think it'll definitely need a specialist indy (or a very good auto electrician) to find the fault .. somewhere. Otherwise I'll end up just randomly swapping ECUs because I can't find a wiring fault :/
Wed Nov 24 2021 3:10pm |
RugHead Member Since: 26 Nov 2020 Location: South Yorkshire Posts: 40 |
Hi mate, don't know if it'll help, but I have a 2012 with the rotary gear selector, a month ago it had a bit of a hissy fit where the car would start but the selector was dead didn't rise and no LEDs came on, luckily it righted it self after about half an hour and has been perfect since, my son ran it past his friend who works at a local dealership, he seemed to think it could have been a problem on the canbus, he advised I check the earth points under the wing because they're seeing alot of canbus faults on older cars due to the earth's, worth a try. |
Wed Nov 24 2021 4:35pm |
Yep worth a try - I belled out the earths to the PCM as all good, but it could be an earth to something else.
Wed Nov 24 2021 7:20pm |
Happened to be around the corner today (taking my dad to his oncology appointment) so stopped for a chat with Alan.. can see why it was convenient for you! He can look at it mid December.. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Thu Nov 25 2021 1:36pm |
Good to hear if anybody can sort it they can. |
Thu Nov 25 2021 7:06pm |
Car is now at Avenger 4x4 so .. I'll let you know how much lighter my wallet gets shortly! (It's already £168 lighter from recovering it there) 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Fri Dec 10 2021 4:17pm |
