Home > Maintenance & Modifications > crank seal
p38
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Firenze Red
crank seal
Hi all iam asking a question for a friend , he has a 2014 RRS autobiography and he has found oil on his drive anyway he took it in to the garage and they said its the crank case pressurizing and blowing the seal the seal was replaced but it happened 2 days later the garage replaced it then told him if it goes again don't come back, so he has asked another landrover specialist garage and they said it could be the filter clogged up and pressurizing the crank casing , he hasn't had the car back yet but were just wondering has anyone had the same or similar. Thanks.
Post #617974 Fri Oct 08 2021 4:12pm
Disco_Mikey
If the seal blows out, then it needs a new oil pump and seal. Currently, genuine LR seals are on back order, and I've had bad experiences with aftermarket seals...
Post #617977 Fri Oct 08 2021 6:48pm
