![]() | Home > General (L494) > Side step corrosion |
TheGoodWillOut Member Since: 18 Oct 2018 Location: TheNorth Posts: 56 ![]() ![]() |
The dealer has offered £500 contribution towards new side steps which are priced at £1300.
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1917 ![]() ![]() |
Get him to give you the money and then buy some decent non LR ones.
I fitted a set of these today & can highly recommend them,,ive fitted loads in the past but none as good as these,no metal to corrode as they are rubber coated.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9138 ![]() ![]() ![]() |
No, it's an accessory not part of the car's structure. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thanks, currently in discussions with LR customer services on as they've admitted the corrosion is really bad and not something expected from a genuine LR part. |
How big a job is it to fit new side steps ? come to an agreement with dealer but will mean me fitting new. |
The ones I fitted took me 35 minutes.If they are just fitting steps onto original brackets,then five minute job. Andy.
Well you have done a few!
I’ve fitted enough & know where all the bolt holes are,the ones I fitted last time were the easiest as their is no cutting of the undertrays.Plus ive got the proper lifts for getting them up in the air. Andy.
Ad_simmo Member Since: 20 Jul 2018 Location: Norwich Posts: 7 ![]() ![]() |
Also had the shocking corrosion on the side steps actually couldnt believe it either - they had completely dissapeared just rusty flakes left. The step basically just fell off when my friend stood on it.
