Home > Technical > ACC problem tdv8 sport
Jefus957
Another issue with my tdv8 the cruise will not engage, scanned and came up with adaptive speed control module fault, problem is Iv'e no idea where its located any help would be appreciated thanks in advance
Post #616842 Fri Aug 27 2021 8:46pm
If you are referring to the Radar Sensor it is behind the front bumper on N/S side, the Control Module is behind the trim panel in the N/S footwell looking at this diagram.
Post #616844 Fri Aug 27 2021 10:43pm
Interesting.
I hadn't realised there was an ECU inside too
Post #616845 Sat Aug 28 2021 8:34am
Just noticed that drawing is a L/H/D illustration so control module may be in the O/S footwell.
Post #616850 Sat Aug 28 2021 9:27am
Jefus957
Thanks for the info will keep looking, its annoying that the initial fault was cruise not available and a scan with the icarsoft vr2 gave adaptive cruise speed module fault, cheers Jeff
Post #616851 Sat Aug 28 2021 10:50am
