![]() | Home > Faults & Fixes > Fragments in oil filter |
| Kot Member Since: 07 Jan 2021 Location: UK Posts: 92 |
If you still have the old oil get it sampled in a test lab, having the material identified is a starting point. |
| Range78 Member Since: 01 Feb 2019 Location: Guyancourt Posts: 19
I did not collect the old oil but I did recover the filter. |
Try flushing the filter with new oil with the hope that small particles of material in the filter is captured in the sample and tell the lab to identify? |
Yes very good idea, I will also help myself with a brush.
| knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139
Personally, I wouldn't drive the vehicle.
| Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 933
Aluminium ??? Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e |
Yes is possible, coming from the cylinder head? |
The glitter could be white metal from crankshaft bearings, get it tested. |
Doubt its from the head, but as stated white metal bearings is possible, could be lots of things but I think it would be pretty noisy. I would not like to be using it until you get a diagnosis or at least get another oil change or at least a filter change to see if the new filter has anything. If nothing, then it gives you peace of mind for your holiday. You don't want it to be a really expensive holiday. If draining the oil check the drain plug for swarf as it may have a magnet on it (oh your particles are non magnetic, forget that) Good luck Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e |
Is this metal attracted by a magnet? |
You are right, I would like to disassemble the filter myself, but I am afraid I will not be able to put it back correctly. Especially at the level of the nipple. If you had a procedure? |
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9138
No. White metal is an alloy of tin, lead, zinc and maybe some other stuff like bismuth. None of the constituents are attracted to a magnet. The backing of the bearing is usually steel which would be attracted to a magnet. I'd be concerned that a bearing was breaking up. That's going to be a new engine (or at the least a rebuild) if you drive it and the crank snaps. Best advice to not drive it until you have established what the metal is and where it's come from. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
