Home > Technical > 2007 sport transmission fault, hdc fault, suspension lowered
AlexC85
Hi all, I am new here and want to thank everyone in advance for taking the time to look at this.
I recently purchased a non runner 2007 sport. 2.7v6. Day 1 was a success, replaced the fuel filter and it ran!! I have since repaired the parking brake module, replaced the airbag slip ring and suspension compressor so quite a few dash lights have been eliminated.
From cold the car drives absolutely fine. I get an engine fault message due to the turbo actuator sticking but I know what that is. After driving for around 10 minutes I get transmission fault limited gears available, hdc fault, parking brake fault and end up in limp mode.
A code scan has been attached. I have checked everything I can think of with no joy.
Any help will be greatly appreciated.
Post #616167 Mon Jul 26 2021 9:52pm
I guess you could still have a fuel problem. That’s common to cause all them dash lights.
May be the high pressure pump
Robbie has a testing guide somewhere
Post #616170 Tue Jul 27 2021 5:51am
AlexC85
Thank you for your reply. I will take a look at the guide and see where I go from there.
Post #616173 Tue Jul 27 2021 11:56am
