Home > General > Should the roof rail be capped off? *PIC INSIDE*
Agent_Trig
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Fuji White
I noticed this morning when looking from the bedroom window that the roof rails, do not have any covers on them - they look a bit unfinished.
Is this normal? and more to the point, should that hole for the bolts be capped off to stop water going into the body?
Post #615976 Wed Jul 21 2021 9:28am
The blanking caps covering the mounting screws holes are missing thats all nothing else missing. They are quite a odd shape and size, unfortunately as normal L/R do not list them separately for the Sport, however they do list some for the D4 roof bars that look the same or very similar so may be worth a try. Part No. DBD500020PVJ
Post #615988 Wed Jul 21 2021 11:09am
Agent_Trig
Would those be grommets to cover the circular holes?
Any idea where I can grab those from? EDIT - just seen you're from NZ... not to worry Very Happy
Post #615991 Wed Jul 21 2021 11:46am
Yes they are, a L/R dealer or just google the number and see what comes up.
Post #615992 Wed Jul 21 2021 11:50am
Pufftmw
I wouldn't say they are "grommets" per se, more like a little plastic cap with a bit out the edge so you can get a small screwdriver in to lever them off. Definitely not rubber.
If your bolt is tight, then it shouldn't let water in, they're just cosmetic.
Post #616008 Wed Jul 21 2021 6:52pm
Agent_Trig
I haven’t got anything bolted in, as not got any bars or roof rack.
So was asking if these should be capped off.
Seems like the whole strip should have a cover to me - looks very unfinished
Post #616009 Wed Jul 21 2021 6:54pm
I have fitted several new genuine L/R roof rail kit's and the only thing you have missing apart from the cross rails not being fitted are the caps shown in the picture, there are no full length covers.
Post #616017 Wed Jul 21 2021 10:13pm
Eagle77
What model do you have? If its a L494 you just have a stock roof then yes something is missing and that should have a cover to make it flush with the roof.
edit - just seen you profile pic ignore me! MY2022 HSE Silver D300 in Firenze Red with black contrast roof
2018 XC90 D5 Inscription with Polestar...gone
2017 XC90 D5 RDesign....gone
2013 Audi Q7...lot of issues...gone
2012 Mercedes CLS...loved it...gone
Post #616042 Thu Jul 22 2021 4:13pm
Eaters
I know what you mean. I bought some genuine LR ones from Buckster on this forum. They are great and the bars have come in really handy. However, they do look unfinished but apparently this is how they are. And from the ground of course no one knows except you. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #616069 Fri Jul 23 2021 1:39pm
