![]() | Home > Technical > IID DPF 3.0 SDV6 |
Bertbuckie Member Since: 04 May 2021 Location: Scotland Posts: 274 ![]() ![]() ![]() |
Hi all, my tool says remaining 0 - is that normal? Seems like it cant read levels tbh? |
No takers? Sorry to bump. Either it cant read it, or its absolutely full at 0.0l ( or empty? ) Very confusing. |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2022 ![]() ![]() |
Field don’t work. Here you go:
Louping jesus! Thanks mate I shall trawl through |
These are the fields I use to monitor soot level, burn temps, oil dilution, number of regenerations and pressure sensor voltage
Can you explain to a retard ( ie, me ) how you got to those values? What exact settings you went into and allowed. I spent ages today when he was in hospital trying live values etc. |
Live Values
Thank you mate, I will get the hang of the IID eventually |
I highly recommend reading the instruction manual |
Yeah I did have a squint, but tbh after years on various tools I just ploughed ahead. I will never forget pressing " reset ECU " on tech 2 in my vauxhall tho hahahahahaha. |
