Home > Faults & Fixes > RRS 2.7 Limp Mode -
knezevic93
Yugoslavia 2009 Range Rover Sport TDV6 HSE Java Black
RRS 2.7 Limp Mode -
Hello to all,
I am new to the forum, so before everything I wanted to say hi Smile
I do have a issue which can be related to many factors I guess since these cars are damn crazy!
Though, I have a Range Rover Sport 2.7 diesel with a following problem.
Car goes into *limp mode* showing following errors:
HDC Fault
Transmission Fault(Specific Gears Available)
Engine System Fault
Parking Break Fault
Suspension Lowered
So I took the car to mechanic and did the following:
Stop Light Break Switch, completely new.
Battery in perfect condition
Alternator in perfect condition
Injectors in perfect condition
Transmission no issues so far
Engine in perfect condition
TCCM Module(computer) no signs on being wet, all good.
After I restart the car, the errors will go away, but they show up on low RPM.
If the car is driving in higher rpm none of those errors will show up.
Recently I have done the service, changing oil and other part such as filter etc etc, as well the breaks.
I am not really sure, as I have no clue what can cause the problem, the OBD once the cars get in limp mode, it shows 25 errors which is reasonable I guess since it went in the limp mode, but one of them is ABS Module.
I have red that fuel filter can cause this as well, today when it happened the car went in the limp mode, i restarted, and the errors were gone, but when i pushed the gas pedal to the very end, in the beginning for second or two, the car struggled to accelerate and after that boom, everything fine and car goes very nice.
Fuel pump as is as well in good condition.
Other known issues is that my parking break doesn't work at all, but I am not sure that that can cause the problem since it was not working from the moment I bough the car, and never had this issues until week ago.
EDIT: Driving in higher RPM the fault won't show up at all, only at lower RPM.
Please find some of the pictures below and any help would be appreciated:
Post #615617 Sat Jul 10 2021 12:40pm
