Home > General > Engine slight surge at low revs |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1245 |
Have you had the codes cleared and read to see what pops up? 2006 2.7 TDV6 HSE in Cairns Blue. |
Mon Jul 05 2021 3:17pm |
Simonhunt72 Member Since: 13 Jan 2019 Location: Somerset Posts: 68 |
Yes ,was none there! |
Mon Jul 05 2021 8:31pm |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
check your adaptive fuel trims. |
Wed Jul 07 2021 10:03pm |
mgrover, thanks for the reply, a garage job obviously then |
Tue Jul 13 2021 12:09pm |
could be yes but they need LR level dealer software to check. |
Tue Jul 13 2021 12:25pm |
OK thank you, any idea what would cause this,as all OK pre service |
Tue Jul 13 2021 6:52pm |
most likely sometimes its as simple as an old gasket causing an air leak.but really gotta look at the trims to tell |
Wed Jul 14 2021 8:37am |
Thank you ,will get it back to the garage I think 🤔 |
Wed Jul 14 2021 11:31am |
