![]() | Home > Technical > Suspension fault |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9100 ![]() ![]() ![]() |
It's a failure that can be caused by two height sensors giving weird readings, or it could just be that the calibration has become corrupted. If the sensors give what appear to be bizarre readings for heights, the system assumes it's gone wrong and sticks the car on its belly. This being the safest ride height - you wouldn't want to be whizzed up to super extended mode at high speed, for example, as it could become unstable.
Cosmo15555 Member Since: 24 Jun 2014 Location: Stevenage Posts: 163 ![]() ![]() ![]() |
I have iidtool so will check live values
You can check the calibration too, of course, with the IIDTool.
I’ve had a quick look at the live value features for the suspension but there are so many different live values to look at do you know which would be the 1 to look at
