Home > Maintenance & Modifications > Rusting around rear power sockets
adriansj
I have just started towing with my 2008 TDV8 and when taking off the rear cover to to tow bar fitment area I have noticed that it is badly rusted. I haven't looked underneath to see if the rest of the rear crash bar is rusted which I assume this part is. Has anyone else had this issue and how have they solved it such as removing and refurbishment and paint with hammarite or a new rear bar.
Thanks,
Adrian
Post #615133 Thu Jun 24 2021 9:14pm
its fairly normal that that panel looks rusty
tidy it up as you wish
I don't think you can replace it, as its part of the chassis
Post #615139 Fri Jun 25 2021 9:19am
You can actualy buy the crossmember separately, but it would be a lot of work as its welded in not bolted, I think L/R did replace a few under warranty when they were having the worn tow hitch issues which might be why it is available, best suggestion wire brush and tin of hammerite .
Post #615140 Fri Jun 25 2021 10:24am
It's just cosmetic really. If it's an issue for you, you could just use a rust eater/preventer on it. Taking the rear bumper shroud off isn't too tricky and this would give access to it and the whole cross member. 2012 SDV6 - it's missing a couple of cylinders
Post #615143 Fri Jun 25 2021 10:32am
adriansj
How do you remove rear bumper shroud?
Post #615146 Fri Jun 25 2021 11:43am
Remove mud flaps
Undo screws in wheel arch , can be rusted tricky so best to remove wheels to loosen screw first.
Remove left rear light to undo connectors
Remove 4 screws along the bottom
Remove trim clips along top with boot open
Pull off from the side of car first
Post #615147 Fri Jun 25 2021 12:09pm
