Home > Maintenance & Modifications > DPF EGR CAT Delete
Bertbuckie
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
DPF EGR CAT Delete
Anyone done as above physical work to a l320 3.0 SDV6?
I am fat and lazy but keep reading people blaming crank failure on the DPF ( Not sure how as I assume torque issue? )
Thanks in advance,
Bert Smile
Post #614897 Fri Jun 18 2021 11:41am
Disco_Mikey
2.7's never had a DPF, and they snap cranks...
Post #614899 Fri Jun 18 2021 12:42pm
Bertbuckie
Ohh? Coming from you that is good info. I did wonder how unless it was regen extra fuel giving more torque.... but it seems a far reach tbf.
I might get under the motor this weekend for a look... probably not tho as its quite a busy one. Shame I cant find any pics or info on removal.
Do you happen to know if its under or on downpipes/ or in the bay?
Post #614900 Fri Jun 18 2021 12:51pm
