![]() | Home > General > Air Suspension Query |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 960 ![]() ![]() ![]() |
I would be tempted to have a good look about for leaks first,,, cheapest option, then consider servicing the valve blocks. 2010 RRS, TDV8
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9136 ![]() ![]() ![]() |
First thing would be to pull the EAS fuses and make sure it's a leak of some form and not a sensor issue. 2012 SDV6 - it's missing a couple of cylinders
Gjlatz Member Since: 01 Mar 2019 Location: UK Posts: 40 ![]() ![]() ![]() |
Hello Gogsy and TDV8, going to get the soapy spray bottle and check the front strut. Before that I will try removing the EAS fuse. That worked a treat with my P38s.
