Home > Maintenance & Modifications > Egr blanking simple solution
savi18
New Zealand
Been in contact with a engine tuning company to blank egr valves and remap ecu to delete egr, he says don’t need to blank egr valves as they make sure egr valves are closed via diagnostics and then delete egr from ecu and the valves remain closed permanently, does this sound so simple and work, if the valves are closed then cannot see why this won’t work.
They withdraw the ecu software and remap it and reinstall. What you think.
2009 2.7 tdv6 RRS
Post #614560 Wed Jun 09 2021 12:02pm
Yeap.
If you have a gap iid you can do it yourself. At a cost
Post #614565 Wed Jun 09 2021 12:45pm
savi18
New Zealand
No gap iid, if I remove the EGR pipes and blank use the 4 blanking plates and also remove the butterfly valve it will put the EML light on I know, but will it go into limp mode as I will drive it the indi about 12 miles away to do the remap.
2009 RRS 2.7v6. Cheers
Post #614698 Fri Jun 11 2021 10:51pm
garrycol
Australia
Driving 12m in limp mode is no issue - so just take the vehicle to your indi. But if your EGRs are stuck open causing you problems now and an eml, then the remap cannot work because they have to be able to close the valves and if they are stuck it is not going to happen. Hence the reason you blank them. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #614702 Sat Jun 12 2021 5:28am
I don't believe the code limits power, so you should be fine driving 12 miles.
Post #614705 Sat Jun 12 2021 10:26am
garrycol
Australia
What limits power is the EGRs staying open forcing all those fumes into the engine when it needs fresh air to develop power. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #614706 Sat Jun 12 2021 11:54am
savi18
New Zealand
EGRs valves are working fine, what I will do is let the indi do all the work then it’s done might be the root to go I think.
Post #614715 Sun Jun 13 2021 12:26am
garrycol
Australia
Well if you are looking at the electronic solution why are you looking at blanking and removing the pipes - not needed when the new program closes the EGRs and deletes the function from the ECU - blanking not needed. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #614716 Sun Jun 13 2021 1:52am
